Does anyone know how to prevent hierarchical ports from being automatically resized? It can cause connectivity issues if the wrong end of the port gets moved as often happens.
In the attached example, A hierarchical block called "MEAS_BAT1" contains a hierarchical block called "COMP" and this has a port/named net called "BALBLE"
The port inside COMP gets resized to be as wide a the string "BALBLE_MEAS_BAT1" when performing various actions like clicking the tabs at the bottom of the schematic editor screen
Place the port in the editor tab, it's the size I'd like it to be
Click the tab for instance COMP1 (located inside MEAS_BAT1)
Go back to the editor tab and it is resized
