I want my vias on the component side almost tented, but open on the bottom. This gives you the ability to capacitive test points for BGA to detect non-solder, good solder, and bridge for each via broke out ball.
I have negative solder mask expansion, top small pad, bottom large pad. I want a fully exposed annular ring on the bottom, but can't do that on the top without possible solder bridging on the BGA.
I can't find a way to specify solder mask extension on top and bottom, just one value. Is the possible in Altium at all?
