As per the above reply, I need to add all components with their parameter manually in Excel & then it needs to use as an EXCEL DBLIB
Sorry, but I'm not following what you're asking there? Are you asking how to set up Excel as DBLIB? Or that you have it set up but can't auto-add, or is this a statement of what you've done?
In case it's the read-only thing, apparently your connection string needs to have "READONLY=FALSE" added to it for Excel.
As a general point, it is no use showing us Robert's videos. It clearly works for him, and I expect that if we could be bothered enough to go through all those steps it would work for us. The problem is that it's not working
for you and we need to know what
you are doing, and how, in order to spot the cause of the problem.
Think about it: you say you have a problem so we simply post a link to Robert's video and say there's your fix. Not getting anywhere, right? So show us, or tell us, the steps that you make to replicate the problem.
