Author Topic: How to find surface mount footprints  (Read 11740 times)
Offline john1201Topic starter
« on: November 11, 2014, 11:59:52 am »
I am very new to altium and was looking for surface mount footprints to add to my library to build a pcb board. I don't know where to find any resistors, capacitors 1206 package. Can anyone help me out?
Offline 8086
    • Circuitology - Electronics Assembly
Re: How to find surface mount footprints
« Reply #1 on: November 11, 2014, 01:04:03 pm »
They are very easy to make.
« Reply #2 on: November 11, 2014, 04:57:10 pm »
Could you explain how to do it?
Offline 8086
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: November 11, 2014, 09:06:10 pm »
go grab my base library
http://siliconvalleygarage.com/downloads/altium-library.html
it's got all you need ot get started. those footprints have been used in thousands of boards.
Online Eternauta
« Reply #5 on: November 11, 2014, 09:39:50 pm »
last version of Altium should import library from Eagle, you can find a large selectio of Eagle library here: www.element14.com/community/community/cadsoft_eagle/eagle_cad_libraries
Offline diyaudio
« Reply #6 on: November 19, 2014, 06:09:17 am »
Many thanks ! I downloaded your library very nice lots of useful stuff mostly common useful stuff.
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #7 on: November 20, 2014, 03:11:29 pm »
One of the great things about Altium is that it is DEAD EASY to create footprints for standard packages.
And, thank you to free_electron for providing that.
free_electron: your download page says you update that almost daily.  Is that still the case?
« Reply #8 on: November 20, 2014, 05:14:00 pm »
it has slowed down a bit. i actually need to push a new version on to the web. i am overhauling the lib with a couple of new features like centroids and courtyards.
Offline futura2012
« Reply #9 on: December 14, 2014, 06:14:45 pm »
hello free_electron
just to say thank you for uploading your general component library.
i am just in the process of learning altium and that is really useful.
Offline maxpayne
« Reply #10 on: January 12, 2015, 10:38:23 am »
You did a great job Free_electron. The library is very impressive ! I see you put SMD resistor value in 3d text. I would like to put such 3d text on the component body on my own designed libary. How can I do that ?
« Reply #11 on: January 12, 2015, 11:08:36 pm »
that is a font i designed as extrusions. there's is somewhere a part that has all characters.
The library is undergoing a massive overhaul right now (both schematic and PCB ). I've learned a bunch of new tricks and i'm implementing them in the library.
Offline maxpayne
« Reply #12 on: January 13, 2015, 03:31:07 am »
That is really great free_electron. How can I design font as extrusion ?
Expecting that we are going to have the update !  ;D
« Last Edit: January 13, 2015, 04:23:09 am by maxpayne »
Offline tautech
« Reply #13 on: January 13, 2015, 04:19:12 am »
There is a generic selection included with Altium in Libraries/PCB/Surface Mount.
I normally use the "M"edium density version for any hand soldering.
« Last Edit: January 13, 2015, 04:28:39 am by tautech »
Offline ElektroQuark
    • ElektroQuark
« Reply #14 on: January 13, 2015, 07:33:45 am »
Quote from: free_electron on Today at 11:08:36 AM
Will those tricks be published in your book about PCBs?
BTW, any ETA for the book?
