Author Topic: Show the parameters from a component in the schematics  (Read 727 times)
Offline tiraxinas
« on: November 08, 2018, 01:44:11 pm »
How to show the parameters from a component when the component is selected in the schematics?
Regards
Offline veryevil
Re: Show the parameters from a component in the schematics
« Reply #1 on: November 08, 2018, 01:59:46 pm »
Properties windows. There is a parameter tab
Offline ajb
« Reply #2 on: November 08, 2018, 05:43:39 pm »
More specifically, you can turn on the visibility for a given parameter in the parameters tab of the properties window, and then you can select the parameter in the schematic to control the visibility of the parameter name separately from the value as well as control its visual style.
