Author Topic: Altium Designer Interactive Routing  (Read 3119 times)
Offline KnaallTopic starter
« on: August 17, 2015, 03:16:31 pm »
Hi reader!
I'm a student doing my masters thesis and I've worked with Altium Designer 14 for a couple of months. Earlier this evening I ran into a problem, for some reasons the interactive routing stopped working. When I route or drag existing tracks I can cross (short circuit) any other track. I checked my settings under "Tools - Preferences - PCB Editor - Interactive Routing" and "Ignore Obstacles" is not checked under "Routing Conflict Resolution" nor "Dragging".
I've also checked so that the "Allow Shorcuts" alternative in the DRC settings is off
I have no clue on how to fix it and I spent a couple of hours trying to find a solution without any luck.
Does anyone know if theres a way to solve this dilemma?
Kind regards / Christoffer
Offline tszaboo
Re: Altium Designer Interactive Routing
« Reply #1 on: August 17, 2015, 03:26:45 pm »
Is the rule itself turned on? If you press D, R and click on the short circuit, does it say enabled?
« Reply #2 on: August 17, 2015, 05:03:53 pm »
Thanks for your reply!
Yes, it is enabled.
But now I managed to solve my problem. I ran the design Rule Wizard and it fixed my problem (but it screwed up some of my rules). I still do not know what caused it but at least I know how to fix it.
