Hi
I have a annoying problem with a multi-channel design in Altium, and there especially with the "Copy Room Formats" command.
It seems, that this command does not take into account, that the room can be rotated, and always copies exactly what is in the source room to the destination room, nevertheless if the destination-room is rotatet or not.
I have made a coarse layout of each room of the project, and than arranged all the rooms in a fashion that will accomodate the desired form-factor of the finished product. In doing so i also rotated some of the multi-channel rooms, thinking, that the copy room command will take care of it. To my unpleasant surprise it prosumably doesn't do that and all the channel-rooms which are rotated from the original room get completly messed up, because the contents of the source room are pasted into it without considering the rotation.
Is there some trick wo make altium do what i need, or is that function of copying room formats just another function, which sounds good on the marketing sheet, but isn't really thought trough, like so often in Altium unfortunately.
