Author Topic: Altium 1:1 print output  (Read 16388 times)
Offline richcj10Topic starter
« on: November 18, 2013, 03:48:17 pm »
I think I have it scaled correctly using the page setup. But when I print, I get a blank page. The printer is B/W and I have tried it in mono and gray. Any Ideas?
Offline owiecc
    • Google scholar profile
Re: Altium 1:1 print output
« Reply #1 on: November 18, 2013, 07:27:11 pm »
Can you see your layout on the preview? Try printing from Altium to PDF. This should tell you if it is Altium or printer issue.
« Reply #2 on: November 19, 2013, 05:58:31 am »
Yes, I can see it on the preview.
How do I get it out of altium in pdf at 1:1 ?
My printer works fine. I can print from any other program.
Offline gocemk
  • Country: mk
« Reply #3 on: November 19, 2013, 12:08:18 pm »
You must set Adobe PDF (or CutePDF) as your default printer, otherwise it won't work. (at least in my case). Then, print it as pdf, and save it. Then you can review your design in pdf and print it on a printer.
Hope this helps.
Offline Psi
« Reply #4 on: November 21, 2013, 08:18:15 am »
(Altium designer summer 09)
Right click on the fabrication previews your printing and click "page setup"
Change the scaling to "Scaled print" and set it to 1
That will print 1:1   (i've used it many times to do toner transfer)
You can print to a PDF printer to get a 1:1 pdf then print later if you want. i've done that too
If you find the output isn't 1:1 when printing the PDF then it's an issue with your PDF software.
« Last Edit: November 21, 2013, 08:30:05 am by Psi »
