Author Topic: SVNdblib to Offline Integrated Lib no go!  (Read 1930 times)
Offline mengfeiTopic starter
  • Country: ph
« on: January 12, 2024, 03:44:03 am »
i have tried to split our svndblib & also create an offline integrated lib & Altium will just stall 4ever everytime!
what could be the problem here? I am doing something wrong?
thanks for any solution given. AD21.8.53
just some info: Manually Placing PCB Footpritns & SCH Symbols from the database takes about a minute for each part to load even thought it is pointing to our local cache on our PC. Another problem that needs to be resolved.
Offline PlainName
  • Country: va
Re: SVNdblib to Offline Integrated Lib no go!
« Reply #1 on: January 18, 2024, 06:41:02 pm »
Don't know, but looks to me like the slow access for placing stuff is what's causing the conversion to appear to be stalled - it is no doubt just taking that long for each part in the library.
I wonder if there is some network access involved. Could it be looking up something that isn't available and just sitting there for whatever the timeout is before giving up?
  • Country: ph
« Reply #2 on: January 19, 2024, 08:04:32 am »
thanks for the input, I think so too, it seems like it's taking those footprints, although locally cached & it's on my local drive, one by one & simulating the placement process (which takes a minute for each footprint) then converting then to an integrated lib.
we still couldn't figure out why some footprints would take like 5 secs while others (LED) would take around 45 seconds. Although this practice of manually placing parts on a specified size PCB is only for testing & not regularly used, the standard SCH > PCB is normal in it's action.
  • Country: ph
« Reply #3 on: February 02, 2024, 01:35:02 am »
now the real problem starts!
placing parts in SCH takes like a minute to place & checking their properties another minute  |O
has anyone using SVNDBlib or even DBlib have this problem?
footprints & components are cached locally while parametric data & other info are stored in a database in SC & all teams around the world are having the same problem
