Hi all,
I have a schematic for a ISA interface board I need to either convert to PCI or replace the functionality using a FPGA board.
I have some experience in Altium now, and I'm loving it ! But I have never designed a PCI board. Is there a template design I can use that converts a design like this so I can just connect up the inputs ? Or perhaps since its such a simple design with only a few through hole ICs perhaps I can even solder up a prototype board like this ? But I know connecting to the PCI bus is complex.
http://www.ebay.com/itm/PROTOTYPE-PCB-FR4-PTH-6-9-x-4-5-PCI-SLOT-Double-Side-Universal-Board-10-/271275986731For some background this configuration interface board configures a switch matrix. It is used with a separate ADC board, and a separate digital i/o card to perform a experiment. I have a board with a spartan LX150 and a full breakout so I'm thinking perhaps I could replace all 3 boards with 1 multifunction board ? The ADC needs to be able to do differential mode.
Please give me your advise and suggestions.
1. how difficult would it be to duplicate the functionality of the schematic in a FPGA ?
2. can a FPGA replace a digital i/o pci board with little effort ?
3. what is the best value ADC I can connect up to a spartan 6 lx150 easily ?
4. are there designs for a pci board I can download for Altium so I can just create a PCB from this schematic and plug the ISA inputs into existing tracks ?
Thanks !!
