Author Topic: Shortcut for interactively route diferential pair connections  (Read 2734 times)
Offline senseyeTopic starter
« on: February 24, 2017, 07:51:57 am »
I am a beginner with Altium and have been looking for the shortcut for interactively routing diferential pair connections. I can intereractively route connections with the shortcut P, T. The answer to the question can seem easy to find, yet I haven't had any success. Does anyone know the shortcut? and even better where could I find the answer for myself? The Shift + F1 or F1 command only works when I am already routing.
Thank you in advance,
S
Offline technotronix
    • PCB Assembly
Re: Shortcut for interactively route diferential pair connections
« Reply #1 on: February 24, 2017, 10:27:56 am »
Find Shortcut for interactively route differential pair connections from here in (Interactive Routing Shortcuts) Section.
http://documentation.circuitstudio.com/display/CSTU/PCB_Cmd-Routing_Composite((Interactive+Routing))_CS
Online free_electron
    • SiliconValleyGarage
« Reply #2 on: February 24, 2017, 08:12:42 pm »
P - I
Offline exmadscientist
  • Technically A Professional
« Reply #3 on: February 24, 2017, 08:16:31 pm »
For some reason they reorganized things and now it's U - I in AD17. (Why yes, this does drive me crazy, why do you ask?)
« Reply #4 on: February 27, 2017, 07:57:38 am »
Thank you very much for the repplies. P, I works for me
