Hey
I'm a little confused about how to calculate the trace length / width for for an a module that is using a chip antenna. I know the antenna trace has to physically match as close to 50 Ohms as possible, but what I can't figure out is if I need to calculate the length of the trace to the 1/2 wave, 1/4 wave or etc..
I picked a generic chip antenna for my Bluetooth module and nothing in the datasheet talked about being careful about the length, so do you guys know what is the best method to use for designing this trace? I used the auto router to give me the width of the trace that would match 50 ohm, which it said was about 20.5 mils, so that is how wide I've made the the trace, I been careful to make to that no cooper is left under the antenna or around the antenna, in accordance with the datasheet.
I've posted a picture of the actual layout of the chip / module, maybe it would help.
Thanks
Docmur
