Author Topic: How to add harness entry to existing port  (Read 1663 times)
Offline willPowellTopic starter
« on: February 21, 2022, 03:52:39 pm »
Hi everyone,
I am very new to Altium Designer and trying to modify an existing port by adding an additional harness.
Currently Altium displays a red squiggly line when I add a new harness entry. How to add harness entry to existing port?
Please See photo attached
How do I avoid this and how do I sync so that it updates the port on the other schematic?
Thanks in advance,
Will
« Last Edit: February 21, 2022, 04:14:36 pm by willPowell »
Offline PlainName
  • Country: va
Re: How to add harness entry to existing port
« Reply #1 on: February 21, 2022, 10:53:48 pm »
Click on the harness body to select it then in the properties panel add the new entry.
Or select Place->Harness->Harness entry :)
« Last Edit: February 21, 2022, 10:55:38 pm by dunkemhigh »
The following users thanked this post: willPowell
« Reply #2 on: February 22, 2022, 04:28:29 pm »
You're a legend  ;)
Thanks, dunkemhigh
