Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Altium Designer - Set PCB Thickness ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Altium Designer - Set PCB Thickness ? (Read 18978 times)
David_AVD
Super Contributor
Country:
on:
July 28, 2015, 04:31:39 am »
I have a PCB that I've exported as a step file, but the board thickness seems to be set as a default 0.3mm or so.
Is there a way to set the PCB thickness (in general or for the step export) ?
Logged
enz
Regular Contributor
Country:
Re: Altium Designer - Set PCB Thickness ?
Reply #1 on:
July 28, 2015, 07:08:33 am »
This is done in the Layer Stack Manager. Menu: [Design] -> [Layer Stack Manager]
Altium calculates the total thickness of the board from the thickness of each layer that you specify there.
Logged
David_AVD
Super Contributor
Country:
Reply #2 on:
July 28, 2015, 10:44:41 pm »
Excellent - thanks very much for that. Job done!
Logged
DutchGert
Frequent Contributor
Country:
Reply #3 on:
August 01, 2015, 11:37:50 pm »
How can u produce a board without defining the layer stack in the first place?
Logged
Zman
Contributor
Country:
Reply #4 on:
August 02, 2015, 07:29:49 am »
nothing is wrong with using default layer stack which is standard top/bottom two-layer (unless you have special requirements)
Logged
Information wants to be FREE!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
