Hello,
I am using two sensors, each with their own FPGA and I want to connect them using a top layer layout.
Since the sensor is 100% the same, I wanted to route all the differential pairs to the outside using a bus, but since a bus needs specific naming (ending with 1 to x) I can not do that, as differential pairs claim the last part of the name with _N and _P.
Therefore I used a harness.
Now I use the repeat on the sensor and want to split the repeated differential pair harness, but I have no idea how.
