Author Topic: How to make this thingy?  (Read 1353 times)
Offline rozehTopic starter
« on: November 10, 2015, 02:03:02 pm »
Guys
I want to make some-things like these on some of my tracks to solder on them:
How to do it?
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
Online T3sl4co1l
    • Seven Transistor Labs
Re: How to make this thingy?
« Reply #1 on: November 10, 2015, 02:09:30 pm »
Put traces on the solder mask layer.
Mask is inverted by default, so any positive shape present on that layer is an opening in the mask.
Note that, if you ever move the (copper) traces, you have to move the soldermask objects as well.  It may be easier to simply set the soldermask property of the trace(s) (but, you can't generate a segmented or striped pattern, like shown; that has to be drawn by hand).
Speaking of PCB things, if you want to make those spark gaps (under the CM choke) as well, I'd suggest making that as a separate component and footprint, then put one in parallel with each side of the choke.  It'll be constructed in exactly the same way: some copper shapes, soldermask opening, PCB cutout, and pads to connect to the nets.
Seven Transistor Labs, LLC
