Author Topic: Opening Component Properties window bug ?  (Read 5351 times)
Offline MetraCollectorTopic starter
  • Country: cz
« on: March 12, 2013, 01:05:59 am »
Hello gentlemen, I have some problem with Altium 9.4.020159 on Windows 7.
When I try to open component properties window, nothing happens. Active window of Altium fades and becomes inactive and it looks like it waits until I do changes in Component Properties, however I DO NOT see it. When I press ESC, it comes back to active.
Same behaviour when I move component and then press TAB or Right Click and select Properties in the menu.
Every other dialog window works and it also works for objects like Texts, Lines, Rectangles. Component Properties is the only does not work.
Anyone have some clue ?
Thank you and regards Ondrej
Offline David_AVD
Re: Opening Component Properties window bug ?
« Reply #1 on: March 12, 2013, 01:23:54 am »
Sounds like the window is off screen somewhere (different monitor).  Have you changed your monitor setup?
  • Country: cz
« Reply #2 on: March 12, 2013, 07:42:21 am »
Yes, I tried different resolution, switch screens, unplug the second screen, run Altium maximized, minimized, open it in little window if Properties isn't opened behind the Altium window.
It seems to Properties do not open at all. :-//
This happens only for Component.
Ports, Lines, anything else works allright.
// I also tried to set everywhere default settings. I am afraid that I will have to reinstall Altium, perhaps I should try newer version if I don't solve this in reasonable time. |O
« Last Edit: March 12, 2013, 11:39:34 am by MetraCollector »
Offline salvodi89
« Reply #3 on: March 15, 2013, 10:39:58 am »
I have the same problem with Relase 10 and windows 7....
I tried everything but widout resoult!
  • Country: cz
« Reply #4 on: March 15, 2013, 01:44:56 pm »
I solved this downloading portable version of Altium 9.4. and works well for now. Sometimes crashes, but it works. :-\
Offline David_AVD
« Reply #5 on: March 15, 2013, 10:01:22 pm »
Maybe login to Altium Live and update?  You do own a legal copy of Altium don't you?
