Author Topic: How to 3D model a complete system of boards ?  (Read 3356 times)
Offline snoopyTopic starter
    • Analog Precision
« on: December 09, 2015, 12:15:14 pm »
Hello
What's the best way to model a set of boards to see if everything fits in an enclosure ?
Do I export a step file of each board and then import them into another CAD package or can I do it in Altium ?
cheers
Offline HighVoltage
Re: How to 3D model a complete system of boards ?
« Reply #1 on: December 09, 2015, 01:08:42 pm »
Well, I do it like you and import the step files to Solidworks and then see, if it fits the housing.
It works well for me, since I do the enclosure / housing design anyways in Solidworks.
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #2 on: December 09, 2015, 01:13:37 pm »
You can do it in Altium just add the 3d bodies and place them according to where they will go (requires some tongue-in-cheek technique and patience):
Probably not a full featured experiences in comparison to tools made for this, but it's enough for my needs.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: December 09, 2015, 03:57:17 pm »
export step for sub assemblies
then make a new pcb file holding only the step files : load step files but do NOT embed them , link em ( click on the 'file' button as opposed to the  'embed' button. )
that way if you alter the step file altium detects a file operation and can reload on the fly.
Offline ajb
« Reply #4 on: December 09, 2015, 04:57:01 pm »
There's a plugin for SolidWorks that allows you to work collaboratively on the same PCB from SolidWorks and Altium, which *looks* pretty nice the last time I saw a demo, but of course requires AD, SW, and the co-design license, so it's not a cheap solution.
The method free_electron describes works fairly well, or if you're designing a PCB that needs to accommodate a finished plug-in board, you can link the step file for the plug-in board into the PCB design file for the main board rather than a separate PCB file.
    • Analog Precision
« Reply #5 on: December 12, 2015, 04:15:10 am »
Yes this seems to work but after loading three boards one board disappears and becomes invisible !! Quite bizarre.
cheers
    • Analog Precision
« Reply #6 on: December 14, 2015, 08:14:12 am »
cheers
Ok it's working better today but the auto update has trouble with large boards and bombs out. Also I got an "out of memory" error with nearly 8 gigs of free memory left in the system !! Altium seriously needs to take advantage of 64 bits !!
cheers
