Author Topic: 365 components  (Read 1904 times)
Offline PlainNameTopic starter
  • Country: va
365 components
« on: October 28, 2020, 11:47:40 pm »
How does one remove the 365-based library from the component list? I once signed into the cloud for something but now keep offline. However, my cloud library is apparently cached and displays in the compent list along with the file-based libraries. That would be bearable but the damn thing is the default and thus completely fills the component list with 60 parts I've never seen before, don't want and wouldn't use anyway.
Offline alexwhittemore
Re: 365 components
« Reply #1 on: December 04, 2020, 08:40:19 pm »
If your top-right corner looks like this, with the blue colorful clouds, you're signed in to an A365 workspace.
1123364-0
I mention this because, for the life of me, I can't figure out how to stay signed out.
If you click that settings icon and go to Data Management > Servers, you can turn off any workspaces you're signed into. If I do this, I notice that my components panel now still has all the same workspace components, but there's a note at the bottom that says I'm working on cached data. Note that at the bottom of that "servers" section, there's a button to "clear cache." The only problem is, "clear cache" instructs you to restart altium for it to take effect, and every time I restart altium, I get signed back in to my workspace.
I tried disconnecting the network to my virtual machine, and indeed after signing out, clearing cache, disconnecting network, and restarting Altium, I have ONLY file-based libraries in my components panel.
So here are a couple possible solutions for you:
1) sign out of your workspace, clear cache as above, and figure out what I couldn't about staying signed out (make sure you never get a blue cloud again in the top-right of the window). Maybe you've already got that sorted, and clearing cache is all you need to do.
2) If you truly don't want/use/need Altium 365 and want all the cloud data management stuff to just disappear, you could go to https://accounts.live.altium.com/, find whatever workspace(s) you activated, and delete them there. I have to assume that'll take care of the components for you, perhaps with a "clear cache" as well.
3) If you MAYBE want A365 features and you're just annoyed about all those demo components you didn't make, you could go to https://YOURWORKSPACENAME.365.altium.com/SettingsManagement#dataCleanup and just blanket delete them all from there. Then ONLY components you make going forward would show up. And of course, you can also delete whatever from the "explorer" panel inside altium as well.
  • Country: va
Re: 365 components
« Reply #2 on: December 04, 2020, 09:26:52 pm »
Not to mention that one needs to sign in to get updates.
I will try the nuclear option #3, thanks  :-+
Re: 365 components
« Reply #3 on: December 04, 2020, 10:11:56 pm »
Not exactly - the workspace sign in should be totally separate from the altium live account your license is associated with. For instance, I have my personal "Alex Whittemore" workspace, and I'm pretty certain I can make as many other workspaces as I'd like in order to, for instance, silo my clients without having to get down to individual project permissions. I guess I should probably play around with that before I try it on billable hours.
Anyway, I think the truly nuclear option is 2, and that sure OUGHT to take care of it. I'm not willing to try it just yet while I'm still using my workspace for playing around, but I may do it soon anyway. I'll try to remember to let you know how it goes.
The following users thanked this post: PlainName
