Author Topic: Component placement according to DXF/Step file restrictions  (Read 3669 times)
Offline guscrownTopic starter
« on: September 26, 2012, 02:19:06 pm »
I'm new to PCB design and new to Altium. I manage to figure out the following:
  • Create my own footprints for odd parts and using the wizards.
  • Import the board shape from a DXF file.
  • Import the board shape from a Step file. Which is neat because it automatically creates pads for holes and everything.
Now I've been going through the wiki and can't really find on how to correctly position parts according to the DXF information or the Step file created pads. I now a little bit of autocad and I know you can use commands like "Select", "Middle", "Move", "Center", etc.. to aid you in the movement and placement of figures. But in altium I cannot figure it out. I don't just want to eye-ball it. As the mechanical restrictions are there for a reason.
In the case of the pads automatically created by the Step file importation, can I place pads over pads? I ask this because of course this pads belong to my parts, and I already have a footprint with the correct pads but I don't know how to link them together. My best guess is I should delete them ones created by the step file and position my footprint instead, but if that is the case, how do I accurately position the footprint?
Check example here:
Offline free_electron
    • SiliconValleyGarage
Re: Component placement according to DXF/Step file restrictions
« Reply #1 on: September 26, 2012, 02:38:56 pm »
You would place components there. Messing with loose pads is a non-no.
So , for the connectors on the left, make a 2x4 pin connector in the library ( sch and pcb ) and place them there. You will see them snap in place.
Once all these are in place you will then simply redefine the board shape ( remove the cutouts )
Done.
« Reply #2 on: September 26, 2012, 03:42:59 pm »
Can I place the pads of my part's footprint over those pads on the left?
« Reply #3 on: September 26, 2012, 08:01:26 pm »
absolutely. no problem.
