Author Topic: sheet entry not linked to child sheet / multi sheet design  (Read 2666 times)
Offline vixoTopic starter
« on: September 27, 2019, 11:14:15 am »
I tried to make a multi sheet design and found myself getting some strange errors. I made a sheet and repeated it 6 times and repeated the inputs, but I keep getting a "sheet entry not linked to child sheet" error when compiling and the changes wont update to the PCB. The ports are the same name, the child sheet is included in the project and the inputs / outputs are the same. I looked in the 'synchronize sheet entries and ports' menu but everything is matched  :-// picture attached
can anyone help shed light on this problem?
Offline thm_w
  • Non-expert
Re: sheet entry not linked to child sheet / multi sheet design
« Reply #1 on: September 27, 2019, 08:37:30 pm »
You have project options for Net Identifier Scope set to automatic or hierarchical right?
https://www.altium.com/documentation/18.0/display/ADES/((Creating+Connectivity))_AD
Offline ajb
« Reply #2 on: September 27, 2019, 08:57:09 pm »
Try renaming the sheet entry from "Repeat(in1)" to "Repeat(volt)"?  That's how the Altium documents show it, the repeat syntax is funky and I think only works if you make the names match between the sheet entry and the wire connecting to it.
Also it looks like you're missing a comma in the Repeat() on the sheet name.
https://www.altium.com/documentation/18.0/display/ADES/((Multi-Sheet+and+Multi-Channel+Design))_AD
The following users thanked this post: T3sl4co1l
« Reply #3 on: September 29, 2019, 02:00:21 pm »
thanks! I had a few problems, one of which was the incorrect repeat syntax, but I also found elsewhere that altium doesn't like spaces in the port names
