Author Topic: Right angle SMA Connector - Altium Designer  (Read 4709 times)
Offline docmurTopic starter
« on: August 23, 2014, 05:37:42 pm »
Does anyone know where to get a right angle SMA connector?   I want to add a stub antenna to my design.
Offline Precipice
Re: Right angle SMA Connector - Altium Designer
« Reply #1 on: August 23, 2014, 05:51:32 pm »
RS? Farnell? Pretty much any of the catalogue disties do them, or ebay if you want to chance your luck a bit on quality.
If you get a TE one, then the 3D models that TE supply are good. Should take about 5 minutes, tops, to make a footprint.
