Our company just upgraded to Altium 14 (14.1.5), and the 'Browse Violations' command in the PCB layout does not appear to function at all anymore in this release. Typically on previous releases I'd hover over the object(s) containing violations, and press Shift+V and a dialog box would pop-up displaying the objects and the rules that are in violation between those objects. The 'Tools' menu still shows the 'Browse Violations' command and its associated Shift+V shortcut, but neither one appears to do anything anymore. I still have the "PCB Rules and Violations" tab which will display all the violations, but it's not nearly as nice to use since it lists all the violations on the board, and not just the ones pertaining to the objects that my mouse pointer is hovering over. Ugh!
Is this a bug in the current release? Anyone else have any luck using this command in Altium 14?
EDIT: Not as big of a problem as I originally thought. See next post for update.
