Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Edit views on multiple library components
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Edit views on multiple library components (Read 1146 times)
rcastle
Newbie
Country:
on:
November 27, 2019, 05:57:40 pm »
Is there a way in Altium Designer 19 to edit multiple library schematic components in a .SchLib same time? I want to make some parameters visible by default (package size, tolerance, voltage rating) when I place an instance of a resistor or capacitor in a design, but I don't necessarily want to go through the hundreds of library components I have already manually. Thanks!
Library files can be found here:
https://github.com/badgerloop-software/hardware/tree/master/libraries
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: Edit views on multiple library components
Reply #1 on:
November 27, 2019, 08:02:00 pm »
Try SchLib Filter panel, query
IsParameter and (ParameterName = 'Manufacturer')
(for example) across all components. Use inspector/parameters panel across lib as well.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
