Author Topic: annotation in multisheet designs  (Read 1453 times)
Offline vixoTopic starter
« on: November 10, 2020, 04:48:05 pm »
When I make designs using multisheet designs the part annotation gets changed to things like R99_nameofsheet. Can i make it so it just annotates parts only with numbers as if it were a single sheet design?
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: annotation in multisheet designs
« Reply #1 on: November 11, 2020, 02:07:06 pm »
Under project options you can modify the physical component names by going to the Multi-Channel Tab.
Typically in large multichannel projects you append numbers to signify the channel offset and then the actual logical designator.
For example:
You have 2 sheets that you use 2 and 3 times respectively. Lets call the first Circuit 1 and the second Circuit 2.
When you go to annotate your design you assign the starting designator of each sheet
for circuit 1 you set it to 100 and for circuit 2 you set it to 200
On Circuit 1 you have a designator like R101, and C110
On Circuit 2 you have a designator like R205, and C202
Now when you go to compile to physical designators you tell it to do the following
$ComponentPrefix$ChannelIndex$ComponentIndex
And the physical designators for the above components turn into:
RX101 and CX110 Where x is the channel index of circuit 1
RY205 and CY202 Where y is the channel index of circuit 2
Since circuit 1 is used 2 times the designators you get
R1101, R2101, C1110, C2110
If you would rather not deal with annotating like this, you can do a board level annotation to make the designators all flat no matter how they were compiled.
**Update**
Another thing to note is that when you go to generate a pdf of your schematic, make sure you are referencing the physical documents if you want to see the whole schematic.
« Last Edit: November 11, 2020, 04:07:25 pm by Pseudobyte »
“They Don’t Think It Be Like It Is, But It Do”
