Closed doesn't mean overlapping (like flood fill in a painting program) it means the tracks are physically joined.
When you grab and move each track intersection with the mouse both ends should stay joined (with new tracks appearing as needed). None of them should come apart when you drag.
Maybe find the two ends it is talking about, using the X/Y given, then change one of the ends to match exactly the X/Y of the other. You might find one is 4.3 and the other is 4.299999 etc..
