Author Topic: Altium - Importing a DxDesigner design  (Read 5232 times)
Offline floobydustTopic starter
« on: April 22, 2016, 04:53:51 am »
I need a way get a DxDesigner schematic project into Altium  |O
The Altium Import Wizard just creates a blank workspace, and I fear it's an old import "feature" as the wiki is years old. There's no log error messages.
Any ideas how to migrate a design over to Altium before I die a slow death in Mentor.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Altium - Importing a DxDesigner design
« Reply #1 on: April 22, 2016, 09:56:02 am »
Beats me. Have you called tech support?
Seven Transistor Labs, LLC
Offline D3f1ant
  • Doing as little as possible, but no less.
« Reply #2 on: April 22, 2016, 11:03:32 pm »
I assume you have the Dx Designer plugin installed and your using the 'import wizard' not just trying to open it directly? I remember I had a similar problem with importing something and it was because I didn't actually have the plugin installed  :palm:. It didn't give me any errors, just created a blank doc.
« Last Edit: April 23, 2016, 03:36:22 am by D3f1ant »
Offline Gribo
« Reply #3 on: April 24, 2016, 11:56:49 am »
I had to do the same in the past, I managed to export the schematic to OrCad 9, checked in OrCad, then imported to Altium. It had lots of errors, especially on the power nets (bad or missing GND and Vcc symbols).
I am available for freelance work.
