Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Altium Designer component mess when importing to PCB
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Altium Designer component mess when importing to PCB (Read 1618 times)
trio36
Newbie
Country:
on:
January 31, 2018, 05:47:00 pm »
Hello.
I am having this issue when "importing changes" into my PCB.
Components from one specific sheet will create a huge room with very high separation between the components.
Identical components are used in the other sheets and they do not seem to have this issue. Also I tried to copy the contents of the problematic sheet into another schematic document. That did not help.
Thank you.
Logged
D3f1ant
Frequent Contributor
Country:
Doing as little as possible, but no less.
Re: Altium Designer component mess when importing to PCB
Reply #1 on:
January 31, 2018, 07:23:37 pm »
I've had this too at times, I think it's somewhat random and been a problem through many versions of AD. What version of AD? I don't recall seeing it for a while.
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #2 on:
January 31, 2018, 08:30:24 pm »
Hm, usually it goes the other direction (imports in a single row, not a column).
Easily enough fixed: select all in room, T, O, L, select two corners of a rectangle, done.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
