Author Topic: Interactive Routing - Curved traces & 'Any-angle' traces  (Read 4679 times)
Offline PoeTopic starter
« on: February 13, 2015, 09:49:54 pm »
So are the 'any-angle' and curved traces a novelty? .. or are there techniques to use them effectively?
I'm trying to hug a curved board edge, but not having much luck.  Can the radius be changed?
Also a bit buggy.  Anytime my mouse moves near a different net, it defaults to 45/90 mode...
Same with the 'any-angle' trace option.  A 30° trace is easily routed through two holes when they're all the same net, but defaults to 45/90 when their nets are different.  Clearance rules check out.  It's like the instant that the interactive routing tool has to account for another net, it defaults back to 45/90.
Offline free_electron
    • SiliconValleyGarage
Re: Interactive Routing - Curved traces & 'Any-angle' traces
« Reply #1 on: February 13, 2015, 09:55:12 pm »
if you have mulitple lines that need to hug in any angle do a multi-route. no point in fudging that yourself. let altium handle it
select the trac ends you want the route and type P-M.  they will all follow you and flow nicely.
« Reply #2 on: February 13, 2015, 10:17:22 pm »
Found that I can slightly adjust the radius with the period and comma shortcuts, but wow is finicky.
I only need to run one trace.  Does interactive multi-trace routing operate similarly to simply interactive routing?
I'm using Winter 09.   I think they added additional curved routing features in 10?
« Reply #3 on: February 13, 2015, 10:23:42 pm »
Multitrace is just like single trace
But eh, winter 09... That is old....
They got new editing features in 13 and up that winter sumer don't have...
