Author Topic: ALTIUM fixed components placement  (Read 4674 times)
Offline kfc_nTopic starter
« on: April 24, 2014, 02:49:05 am »
Dear people,
             How can I place a pre-placed component in a PCB using altium? for example..the component must be placed from x=19.5mm and y=20.5mm of the board... TIA!  :)
« Last Edit: April 24, 2014, 03:17:02 am by GeoffS »
Offline David_AVD
Re: ALTIUM FIXED COMPONENTS PLACEMENT
« Reply #1 on: April 24, 2014, 03:11:08 am »
Do you mean you want to specify the component's x and y coordinates in the schematic?   :-//
Re: ALTIUM fixed components placement
« Reply #2 on: April 24, 2014, 03:24:53 am »
exactly. :) sorry I'm just a beginner in ALTIUM..
and also, how can I delete a polygon placed on whole board..thanks
« Reply #3 on: April 24, 2014, 03:25:20 am »
placement will be on PCB not in schematic
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: April 24, 2014, 04:43:09 am »
Click component and in the inspector set x and y coordinates
« Reply #5 on: April 24, 2014, 04:46:12 am »
so as a default, ALTIUM has an origin lower left side of the board set as (x=0,y=0)?
Online AlfBaz
« Reply #6 on: April 24, 2014, 05:14:17 am »
No.
If you want that you can set the origin to where you like... it's in under one of menu items somewhere
« Reply #7 on: April 24, 2014, 05:46:44 am »
thanks I found it, after, changing the board origin, I can now re-position any components to its proper placement in the board..thanks..
