Lewin's cultists truly believe that 1/4 of the transformer wire turn do not have 1/4 of EMF on it because when they try to measure using voltmeter, by placing voltmeter leads next to wire they measure, they see 0V - as expected.
If,
as expected, the voltage measured across a piece of wire is zero, it is because it IS zero. Any other conjecture about that voltage is absolutely moronic in the context of our discussion.
It is obvious that Faradays' law of induction do not care - it is test circuit or voltmeter leads, but Lewin's cultists are stubborn, they claim that they know better and for some reason voltmeter leads are not influenced by time-varying magnetic field of experiment, only circuit.
Faraday's law of induction doesn't care about wires, leads, probes, whatever. They're irrelevant. They're not even mentioned in the law.
What Faraday's law of induction says is that the
TOTAL EMF around a
CLOSED ARBITRARY path, any path, whatever path in whatever portion of the SPACE, is proportional to the rate of change of the magnetic field INSIDE the area, whatever area, delimited by the aforementioned closed PATH.
So, if your meter, your probes and your wire under test constitute a closed PATH that delimit an AREA where the magnetic field doesn't change or, better yet, where there's none, the EMF is NULLE (in Latvian), i.e. ZERO, нуль, صفر, 零, μηδέν.
So there's no EMF, no belief, no cultism, no Lewin. It is only the theory, which by the way was extensively reviewed and tested by the most brilliant minds of our recent times, agreeing with practice.
Lewin, the Lewin cultism, the belief, and the phantasmagorical EMF that you claim is present in the wires is just an artificial construct that only exists in the brain-damaged mind of a KVLiar. No scientist, professor or author, dead or alive, will agree with you.
In short - fact that Lewin and his cultists struggle to properly measure EMF, do not mean it does not exist.
We, you and all the other cabrones like Mehdi, Mabilde, Jesse and the RSD dude, measure and the voltage is zero (or to be precise it is the current times the resistance of the wire), exactly like the theory predicts.
I told you in the other discussion we had three years ago that you don't understand electromagnetism because you're a "circuity" guy. You're limited to wires. No wonder, Kirchhoff was obsessed with them. They're the essence of his laws. Maxwell's equations made us understand the phenomenon of electricity and magnetism beyond wires. The universe is plenty of an unfathomably large number of electromagnetic events and it is not even wired.
So free your mind and give Lewin a kiss in the cheek.
