Poll
how can i bypass the  IL4558?
bypass the  IL4558
0 (0%)
reduce the gain on the  IL4558
1 (100%)
Total Members Voted: 1
Author Topic: bypass a IL4558 on a phono amplifier.  (Read 2691 times)
Offline AFSR
« on: February 26, 2014, 04:03:29 pm »
i have an old sony stereo and has a phono input! but its to sensitive for connecting any device to it!. you barely give it any input and distorts. can i bypass the IL4558 that is just after the input jack's? how can i lower the gain of these input?
Offline dr_dan
Re: bypass a IL4558 on a phono amplifier.
« Reply #1 on: February 26, 2014, 04:29:29 pm »
A few years ago I used this circuit - it lowers the input level and compensates for the non-flat input characteristics of the phono input.
http://www.epanorama.net/circuits/phono.html
Offline AFSR
« Reply #2 on: February 26, 2014, 04:46:38 pm »
that is great! but i will not use the phono input anymore ( have no turntable). can i just remove the il4558 and bypass the pins? >:D
« Reply #3 on: February 26, 2014, 07:12:13 pm »
Would recommend you just remove the feedback network and turn the 4668 into a plain buffer amplifier instead. Then add an attenuator on the input side as it will still need about 6db of attenuation to handle a standard line level input.
