Author Topic: SEIRO I&E M4032 LCD Amp Hour Giveaway  (Read 2998 times)
Offline shamanjoe
« on: August 30, 2013, 03:17:45 am »
Hi all. I was wondering if anybody else, like me, listened to the Amp Hour, found Dave, and migrated over to this forum.
I got the SEIRO I&E M4032 LCD display which was a giveaway from a sponsor some months ago, and I was wondering if anybody has the pinout for it. I have found all sorts of data for the display driver chips on the back of the LCD, but nothing on the pinout of the  board itself. I believe it's a 42x2 character display, and it has a 15pin header wired to it. Other than that, I don't know much about it, it was new-old stock that was being given away to listeners. Thanks Again!
Scott
Offline Orpheus
Re: SEIRO I&E M4032 LCD Amp Hour Giveaway
« Reply #1 on: August 31, 2013, 02:43:46 am »
You might have more luck looking for SEIKO, not SEIRO. This was a fairly common display 10-20 years ago. I successfully downloaded some datasheets when I got mine.
I don't think I can attach PDFs, and custom search engines don't give linkable results but try these links:
http://books.google.com/books?id=rI0c8kWbxooC&pg=PT348&lpg=PT348&dq=Seiko+m4032&source=bl&ots=mN6oJPqhkk&sig=he_3BRmRyrx-6OMrhuX2_ztdEwk&hl=en&sa=X&ei=q1UhUpjIDouWrAeD6oEY&ved=0CE8Q6AEwBw#v=onepage&q=Seiko%20m4032&f=false
http://www16.us.archive.org/stream/EmbeddedProgramming/8051Cmicro_djvu.txt
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: September 03, 2013, 09:25:37 pm »
Another interesting reference is shown below:
http://wpc.306e.edgecastcdn.net/80306E/onsetcomp_com/files/manual_pdfs/8TXB_Man.pdf
In section 7 (page 317)  it says it has the exact same interface as the Seiko M1632 and a short schematics.
Offline shamanjoe
« Reply #3 on: September 04, 2013, 11:05:23 pm »
Thanks very much. The name is at the very edge of the PCB, so the top of the K really does look like an R, at least to me  :palm:
I'll post some pics once I get it up and running!
