Author Topic: T-shirts!  (Read 25989 times)
Offline Dataforensics
Re: T-shirts!
« Reply #25 on: May 16, 2013, 03:16:49 pm »
Not that I am implying board members are dirty, but has anybody washed their shirt yet?
If so has it shrunk at all?
I ordered an XL and this size with American shirts is normally slightly loose on me, however this shirt is a bit tight.
If they shrink, I will use the two eevblog ones on order as presents I think and order XXL next time.
Tony
Offline Fezder
  • Lean on, or was it learn on?
Re: T-shirts!
« Reply #26 on: May 16, 2013, 06:43:15 pm »
Tony
haha, or if someone washes it for other reason before wearing one? but, i dont think they'll shrink much, and after all, when you wear any piece of clothes, i'll shape towards body shapes....but i would think that maybe you should use that bigger one, and give smaller as gifts, tight t-shirt is one of nastiest things....but this is all my opinion :D
Both analog/digital hobbyist, reparing stuff from time to time
Re: T-shirts!
« Reply #27 on: May 16, 2013, 07:57:43 pm »
Tight T shirt is alright with certain people.......... just saying.
I generally always wash new clothes before using them, you then can see if the dyes will run, if the cloth will shrink and if it will dry misshaped.
Offline Fezder
Re: T-shirts!
« Reply #28 on: May 17, 2013, 12:51:09 pm »
good point regarding dye, newer thought that!  :-+
Online EEVblog
Re: T-shirts!
« Reply #29 on: May 17, 2013, 01:42:40 pm »
Printfection shirt (left) vs the TeeSpring shirt (right)
The Printfection one is essentially 2 colour, but the Teespring one is much better and coler to the original hand drawn style. In fact it has a very funky texture.
I'm not sure why the Printfection one is so 2 colour drab? Is it the printing process or pre-processing of the uploaded image?
« Last Edit: May 17, 2013, 01:44:46 pm by EEVblog »
Offline AlfBaz
Re: T-shirts!
« Reply #30 on: May 17, 2013, 02:11:15 pm »
That's a pretty big difference, I'd be pretty pissed at printfection if I had done a run of shirts... and where's mine? I'm only an hour down the coast from you!  >:D
Re: T-shirts!
« Reply #31 on: May 17, 2013, 04:04:37 pm »
Different screen manufacturing techniques, the one is using 3 ink colours and 3 different screens, while the other is just using 2 screens and halftones to get the image density changes. The 3 screen method uses extra time and needs 3 ink cycles and drying between passes to dry the ink, though you can get a high rate with care and a 6 screen carousel with alternate screens used to dry ink, but this takes care and practice. 2 colours has a higher rate on the same carousel, you skip 2 stages each time.
Offline Fezder
Re: T-shirts!
« Reply #32 on: May 19, 2013, 06:55:44 pm »
It's now tested, washing has no negative effect on shirt, no shrinking/mis-shaping, bleaching of text/ink or whatsoever :).
Re: T-shirts!
« Reply #33 on: May 19, 2013, 07:13:17 pm »
Mine is at the post office, got the slip today............ Gotta pay duty to get it though.... $10 to get it. Wonder if it is one order or 2, or will i get another for the second one.
Offline iloveelectronics
  • Country: hk
Re: T-shirts!
« Reply #34 on: May 20, 2013, 09:35:05 am »
Gosh...$10 duty for a $15 shirt?!
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Re: T-shirts!
« Reply #35 on: May 20, 2013, 05:18:15 pm »
Gotta pay the man..........
Offline c4757p
  • adieu
Re: T-shirts!
« Reply #36 on: May 20, 2013, 05:22:46 pm »
Lord knows the government would go bankrupt if they didn't make 67% off every imported T-shirt!  ::)
Have to say, I'm grateful the worst hardship I have to get the vast majority of packages is the 250 foot (that's 76m for you normal folk...) walk to my mailbox.
Re: T-shirts!
« Reply #37 on: May 20, 2013, 05:34:58 pm »
Was going to hoof it to the PO today, but when I looked next it was home time............ Tomorrow got to go get some clutch plates made very quickly, as the old ones I looked at in the industrial gearbox are looking very sick currently, they are busy falling apart, but as they are in a cage they still work, but still need new ones before the remains fall out. Clutch and Brake place will make as per sample....... Still got one left as sample. Then need to get out the 65AF socket and breaker bar to undo the nut.
Practised my Recoiling skills again, go to undo one bolt and it just came out complete with corroded thread. went and got the kit and the hand tap, and then recut the whole hole through the alloy base and installed the extra length M6 insert and put the bolt in again.  Need to order a few more inserts now, M6, M5, M4, M3 are all low, but on the plus side still have plenty of M16 and M12 inserts around.
Offline Fezder
Re: T-shirts!
« Reply #38 on: May 20, 2013, 06:50:08 pm »
haha, ''normal'' people,i laughed loud :D but, nice service, or, bigger mailbox? ;D
Offline aargee
Re: T-shirts!
« Reply #39 on: May 24, 2013, 01:21:20 am »
Any Aussies got theirs yet? Still waiting here in Queensland.
Not easy, not hard, just need to be incentivised.
Online EEVblog
Re: T-shirts!
« Reply #40 on: May 24, 2013, 01:25:40 am »
Yeah, I have my AmpHour shirt and my 555 Timer shirt.
Still waiting on the Negative Feedback one.
Offline aargee
Re: T-shirts!
« Reply #41 on: May 27, 2013, 08:32:25 am »
Amp hour T has arrived - nice!!!
Offline peter.mitchell
Re: T-shirts!
« Reply #42 on: December 24, 2013, 09:17:18 am »
As Christmas is coming up, I thought i'd have a look around for T-shirts to suggest people get me (to avoid getting novelty farting toys) and I was wondering when you guys were next looking to make some more?
Offline ChrisGammellTopic starter
    • Chris Gammell's Analog Life
Re: T-shirts!
« Reply #43 on: December 26, 2013, 09:02:36 pm »
Well, I suppose it's finally time to roll this out. They're not cheap, which I apologize for, but we're not getting any profit either right now (the dark shirts cost more to print for some reason). These are the same shirts we send out to people for contests and such.
http://www.printfection.com/theamphour
Re: T-shirts!
« Reply #44 on: December 27, 2013, 08:20:27 am »
Wooo! Not cheap? I see nothing at all wrong with the prices, nothing to apologize for!
Re: T-shirts!
« Reply #45 on: December 27, 2013, 05:04:18 pm »
Well, we had them all at 25 before to get a couple bucks per shirt. But once you factor in shipping, that would have been well over 30 for most people, significantly more for people outside the US.
Offline MatthewEveritt
Re: T-shirts!
« Reply #46 on: January 31, 2016, 11:54:52 pm »
The black shirt is being reprinted by teespring, three days left to order. link
Online EEVblog
Re: T-shirts!
« Reply #47 on: February 01, 2016, 04:33:03 am »
156 sold, get yours before they go!
https://teespring.com/theamphour-black
Offline Royce
Re: T-shirts!
« Reply #48 on: February 10, 2016, 05:57:10 pm »
I used the "I still want one" button to reserve a T-shirt for the next run. It said only nine more people needed to reserve the T-shirt for it to go again.
Offline Divvi
Re: T-shirts!
« Reply #49 on: February 12, 2016, 06:08:51 pm »
Just reserved one, need 8 more for another run.
