Hi!
I am designing a Micro-mouse robot as a hobby project. I did the schematic using the EasyEDA online editor. that is because i can directly chose parts from LCSC.
(I use LCSC because of the lowest shipping rates). however, after creating the schismatic using EasyEDA, I convert it to a PCB and then exported it as a Altium PCB ducument(.pcbdoc) to do the routing.
Once I opened the file from Altium it works fine except for that there is a white box around each component. (as shown in the attached image. it only appears once i selected the component)
it seems to be a clearance thing. as in the image 1 , I cannot move R48 or R50 closer to the SW5. when the components are in either horizontaly or verticly, this white box is basically the package outline and its ok.
but when i rotate a component, it becomes bigger. How can i get rid of this ? i am using AD19.
Thank uou.
