Author Topic: [ window voltage comparator ]  (Read 20816 times)
Offline texane
« on: October 17, 2009, 10:25:42 am »
As a beginner, I am reading the following book: practical electronics
for inventor, from Paul Scherz.
For a light sensor project, I need a window voltage comparator. I use
one from the above book. I attached the schema.
What should happen:
Vout is +5v when 2.3v<Vin<2.7v
Vout is 0v otherwise.
However, I get the opposite...:
Vout is 0v when 2.3v<Vin<2.7v
Vout is 5v otherwise.
I use a lm339 quad comparator, so that I actually has only one
comparator. I tested the comparator inputs/outputs independently
to see if it works, and I get right measures. Maybe there is something
I didnot understand regarding the above schema...
Any idea?
Thanks for helping,
Regards,
Fabien.
Offline texane
Re: [ window voltage comparator ]
« Reply #1 on: October 17, 2009, 10:40:03 am »
I think I misunderstood something... the schema
actually works as expected, sorry for posting :)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: October 18, 2009, 08:41:46 pm »
if you get a similar situation again (thats if it really happens) reverse the inputs on the comparators
