Author Topic: [ASK] Converting typical Buck switcher into split rail power supply  (Read 3449 times)
Offline BravoVTopic starter
  • +++ ATH1
Just curious if is it that simple to make a typical Buck switcher to generate positive and negative rails using this method ? Any other considerations ?
TIA
Edit : Some corrections
« Last Edit: November 13, 2016, 08:37:54 pm by BravoV »
Offline Paul Price
Re: [ASK] Converting typical Buck switcher into split rail power supply
« Reply #1 on: November 14, 2016, 02:51:41 pm »
No.
If the circuit you show is very lightly loaded both the Virtual-Ground and V+ outputs would have about the same output voltage refereced to V-Negative.
« Last Edit: November 14, 2016, 03:03:52 pm by Paul Price »
Offline chris_leyson
  • Country: wales
« Reply #2 on: November 14, 2016, 03:25:16 pm »
You could also us a single switch in a combined SEPIC and Cuk converter, see Analog Devices app note AN-1106. http://www.analog.com/media/en/technical-documentation/application-notes/AN-1106.pdf Another option is a "flybuck" converter and wire up the coupled inductor to the negative rail, a word of warning though the rail generated by the coupled inductor has NO short circuit protection.
  • +++ ATH1
« Reply #3 on: November 14, 2016, 03:45:48 pm »
No.
Are you saying the V-Ground and V+ must be loaded all the time, or both rails V+ "and" V- must be loaded at the same time and all the time ?
I got the idea after reading TI's app note -> SLVA369A - Creating a Split-Rail Power Supply With a Wide Input Voltage Buck Regulator , and thinking if I can apply the example like this one below at "other" buck switcher ?
  • +++ ATH1
« Reply #4 on: November 14, 2016, 03:47:06 pm »
Thanks Chris, never read that b4, noted on the short circuit weakness.
