Author Topic: Bench PSU Fault.  (Read 14813 times)
Offline orbiterTopic starter
  • -0 Resistance is Futile
Re: Bench PSU Fault.
« Reply #25 on: November 10, 2016, 08:10:34 pm »
Thanks for that. I've still got that PSU in the garage somewhere with the original fault. I'll dig it out sometime and see if it's the same thing.
Thanks again
Offline ProBang2
« Reply #26 on: November 11, 2016, 08:36:50 am »
I know this topic is 5 years old, but just had EXACTLY the same issue.
The problem was the 100nF debounce cap next to the down button. I had a dual output and both CC exhibited the same fault. Changed Both debounce caps and all working normally.
Just thought i'd leave the comment here if anyone else has the same issue.
 :-+ :-+ :-+ :clap: :clap: :clap: :-+ :-+ :-+  :clap: :clap: :clap: :-+ :-+ :-+
Offline macboy
« Reply #27 on: November 14, 2016, 03:52:10 pm »
Have you considered that the problem might be that you turned the output voltage down to zero prior to connecting the load and setting the current? To operate any supply in constant current mode, the output set voltage must be higher than the expected voltage across the load for a given current. Zero isn't.
Consider that a bench supply has two essentially separate control loops which will limit the output: a voltage control loop and a current control loop. The voltage control loop allows the output current to increase until the set voltage is reached, then it restricts the current. The current control loop allows current to increase until the set current is reached. Both operate simultaneously, and the first one to reach its limit is the one which regulates the output and thereby determines the mode of operation of the supply at that given instant. For CV operation, the current limit must be set higher than the load will draw at the set voltage. For CC operation, the set voltage must be higher than the voltage drop across the load at the desired current.
