Author Topic: [Help] Finals Steps with Altium  (Read 7864 times)
Offline simon66Topic starter
« on: October 23, 2013, 05:01:47 am »
Hello all,
I've been a eevblog viewer for a few months now and I finally decided to join.
I've used eagle CAD for all of my personal projects. A friend of mine bought me Altium Designer 13! I was able to design my project but this is also my first time sending it to a fab (oshpark.com to be specific)
How can I create a keep-out Layer? On my project the "board shape" is what I want my final board to look like. I've seen some places and they have some fancy lines around which I don't have.
Can some one take a look at my project and point me out what I did wrong? Or what I can improve on? Any help is appreciated!
Thank you so much!
« Last Edit: October 23, 2013, 05:03:41 am by simon66 »
Offline David_AVD
Re: [Help] Finals Steps with Altium
« Reply #1 on: October 23, 2013, 05:23:26 am »
I always draw the board outline on the keep-out layer with the keep-out attribute checked.
EDIT: I usually have the traces coming out of the centre of pads, especially round ones.
« Last Edit: October 23, 2013, 05:25:05 am by David_AVD »
« Reply #2 on: October 23, 2013, 04:31:50 pm »
That's my problem I think. How do I draw the board outline. I see info on the wiki but nothing really that helps me out.
Thanks!
Offline M. András
  • Country: hu
« Reply #3 on: October 23, 2013, 05:08:29 pm »
like a track.  draw a line simply shortcut is p+l, switch the to keep out layer and draw it there, same with silk screen if you want custom shapes and you can define the board shape from the menu too
« Last Edit: October 23, 2013, 05:10:47 pm by M. András »
Offline Rufus
« Reply #4 on: October 23, 2013, 06:40:47 pm »
You seem to have already defined the board shape (which is very difficult to manufacture with the square internal corners).
You can manually draw lines and arcs around it on a mechanical layer to provide the manufacturer with the outline. The 'Design | Board Shape | Create Primitives from Board Shape' will do it for you automatically.
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: October 23, 2013, 08:56:57 pm »
DRAW THE BOARD SHAPE ON THE KEEPOUT LAYER.
IF THE LAYER IS NOT VISIBLE
O-L AND TICK THE 'KEEPOUT LAYER CHECKBOX.
THEN DRAW USING ARCS , LINES WHATEVER
S-Y SELECT ALL ON LAYER ,
D-S-D  DESIGN BOARD SHAPE DEFINED OBJECTS
Oops didnt meant to shout. i'm in altium designer right now so capslock is on ... before i looked at what i wrote...
« Reply #6 on: October 23, 2013, 09:00:29 pm »
Thanks! Does it matter how thick the line is? The "Create Primitives from board shape" does the trick faster but I keep getting some errors (Due to default Rules). I was able to make it but not sure if the line thickness matters.
Thanks again!
Offline AlfBaz
« Reply #7 on: October 23, 2013, 09:30:34 pm »
I was wondering who was making all that racket. Thought there was a fire!! :)
Offline mrflibble
« Reply #8 on: October 23, 2013, 09:37:56 pm »
Is this some secret Altium handshake for those in the know? Turn capslock on, it will give you better PCBs? O_o
« Reply #9 on: October 23, 2013, 11:03:33 pm »
Leaving capslock on in altium has an advantage ...
netnames and part designators are all neatly in capital letters like they should be.
Offline mrflibble
« Reply #10 on: October 23, 2013, 11:40:34 pm »
MY NETNAMES ARE IN CAPS TOO, BUT I DONT oh wait, but I dont have capslock on for that. So basically, uppercase netnames. Check!  :-+
Incidentally, do you use netnames starting with a plus/minus sign for supplies (a la +1V8, -12V), or some symbolic name like VCC/VDD/VWHATEVER?
Offline David_AVD
« Reply #11 on: October 23, 2013, 11:44:08 pm »
I use a 10 mil line for the board outline.
Offline AlfBaz
« Reply #12 on: October 24, 2013, 12:32:31 am »
While we're at it what about net names with an Overbar or to put it another way, active low net names. Sure it looks pretty in the schematic** but locating these in the PCB netlist is not much fun when you have to type /l/i/k/e t/h/i/s
So do you suffer the mangled netname or go for something like the preceding underscore system
**When placing net lables on multiple pins the font size and pin grid conspire to hide the overbar with the above wire |O
Offline Rufus
« Reply #13 on: October 24, 2013, 12:58:44 am »
I have settled on a lower case 'n' prefix. If the nets come from a processor or programmable logic I want to use the same names in the firmware or HDL.
Supply rails I generally name like V5V or V3V3 or VM5V (for -5) but not strictly. It depends what makes most sense for particular circuits.
« Reply #14 on: October 24, 2013, 01:15:49 am »
P12V N12V V3V3 V5V L3v3 A3v3
Positive 12 volt
Negative 12 volt
Voltage 3v3
Voltage 5V
Logic 3v3
Analog 3v3
thats how i work.
please dont use overbars on netnames ! the problem is on dense schematics the overbar tends to disappear under a wire of the pin above ! and thi cause problemsn
use lowercase n before or after netname to indicate active low
nRESET
RESETn
I leave capslock on when in altium as netnames , part designators part values are always uppercase
120R 1K2 12K 120K 12R 0R33
1U 10U 10N 2U2 (CAPACITORS)
1UH 2U2H 10UH    (INDUCTORS)
AD720 LM317  .
Nobody writes lm317 or ad720
also : NEVER EVER use dots orcommas in part values. use the Multiplier letter instead of the dot. : 12.7K = 12K7
dots tend to disappear if you copy a printout... and your 12.7k becomes 10 times larger ...
Offline ludzinc
    • My Misadventures In Engineering
« Reply #15 on: October 24, 2013, 01:49:35 am »
IMHO, k should be lowercase, as it's defined in SI units.... i.e. 1k2 not 1K2.
Offline c4757p
  • adieu
« Reply #16 on: October 24, 2013, 01:52:18 am »
I actually prefer lowercase k simply because it's less likely to be mistaken for a capital R in a shitty scan/copy (and if you think scans can't be that shitty.... trust me, they can). SI is irrelevant, they also define both m and M but you're a dumbass if you use both of those in a schematic. And they sure as hell don't define the "1k2" notation.
