Hello peeps, Ive been learning electronics from the internet (ikr) on and off for a month now, and Im set an “ultimate goal” so to say to build a 5/10kW electric kart? golf car? some kind of LEV with two pmsm motors and a custom controller/driver. But Im sure I have plenty to go before I should be working with either 100+V or A. I was also insistent on using sodium ion cells for some reason so there’s also challenges that come with that(72V pack goes from 95V max to 36V cutoff lmao, but ofc I don’t need to always extract everything)
I know basic electricity from studying physics in HS, and some design patterns and parts from strolling around the net, including a great series about BLDCs from Jantzen Lee, which taught me a lot of higher level concepts about controlling BLDCs(well, PMSMs but theyre similar), but there seems to be little in the way of more practical information about handling higher power currents through the pcb or how to connect to the thicc bolt terminal things, probably because it’s much harder to get right just for a video. I did find an EV inverter teardown video from DENKI OTAKU and that gave me some good ideas, but the details are still pretty faint. Im also slowly going through MIT’s 6.002 Circuits and Electronics(2007) on OCW though that’s more fundamental(and has countable number of pixels), maybe I should move to 6.622 Power Electronics (2023).
So in a way Im asking for two things here, for one Im looking for some resources to learn about the specifics of dealing with high power, safety and execution wise. Like Im looking for MOSFETs and they barely go above 100A from TI and seems to be limited to 200A by the leads from Infineon so Im not sure how to get some more safety margins, maybe the way is to parallel them? But that seems like a different set of wormholes. Overall I just don’t feel… comfortable? confident? with power electronics yet as I am with lower power, like I don’t know how to design a pcb specifically but I can’t be *that* much off, I feel like I can always get it working even if I need to hack it, at least I know what to hack. But with high power, I’m just clueless, like there are things that I have zero idea on what to do like connecting the components, I feel that I am missing still some crucial pieces of information to make it all “click”.
On the other hand, I would also love y’alls opinion on what I can do to prepare myself up to this big project. I got a gimbal bldc already because I wanted to make the SmartKnob, maybe I should do this first? What should I do next?
Also I should mention that I haven’t gotten a power supply or oscilloscope yet(other than an USB oscilloscope and a low? current .5A multi-voltage board) but I’ll get them soon when I get a space in a few months(space constraints in my home). I do have a decent multimeter and soldering setup though if that counts for anything. And since I mentioned this, equipment advice is also welcome lol.
Sorry in advance if anything was hard to understand, Im very bad at writing long passages and it can become decoherent.
