Author Topic: KSGER T12 plastic enclosure version grounding  (Read 534 times)
Offline Nooobie
  • Country: il
« on: September 22, 2021, 09:26:01 am »
I am new to this forum, but I read quite some posts about the KSGER grounding problems.
I have the plastic enclosure version of the KSGER T12, and I am concerned about grounding, I understand the the enclosure doesn't need to be grounded but I am worried about the metal connector and the iron itself, does it need to be grounded?
how do I test if it's grounded? I have UNI-T 33C+ multimeter, can I test ground with it?
Thanks a lot to anyone who replies. :-+
Offline ledtester
Re: KSGER T12 plastic enclosure version grounding
« Reply #1 on: September 22, 2021, 03:06:26 pm »
It is safer for yourself and the components you work on if your iron tip is grounded:
https://www.eevblog.com/forum/chat/does-you-soldering-iron-have-grounded-tip/
Also, any exposed metal - especially something you could touch - should also be grounded.
To test if an exposed piece of metal is grounded, check the continuity with it and the ground pin of the mains plug. On the 33C+ the continuity test is the same setting as the diode test (about the 8 o'clock position).
Offline Nooobie
  • Country: il
« Reply #2 on: September 22, 2021, 08:14:32 pm »
Thank you so much for your reply  :-+
I will test for ground with my multimeter,
But all this time I am wondering how to ground it?
I mean the tip may be grounded for ESD as I have seen in reviews (I will test it myself of course as soon as I can), but I have no metal housing to ground the iron connector and the control knob to.
I thought about soldering a ground wire but I am not sure how good this solution is.
« Last Edit: September 22, 2021, 08:22:25 pm by Nooobie »
Offline ledtester
« Reply #3 on: September 23, 2021, 01:24:52 am »
I found this thread on grounding a T12 tip:
https://www.eevblog.com/forum/reviews/how-to-get-rid-of-fluctuating-voltage-on-soldering-tip-(t12-clone-station)/
Seems like one of the pins on the handle connector might go to the tip.
Offline Nooobie
  • Country: il
« Reply #4 on: October 16, 2021, 10:10:17 am »
I finally was able to disassemble the T12 because I didn't find any screws and found no one the plastic case online taking it apart.
I have tested and there is continuity between two prongs in the 5 pins iron connector, and the tip of the iron is also showing continuity with the ground prong,
the metal part of the socket isn't grounded.
I think I have made some mistake because I wasn't able to measure resistance as the reading changed every second drastically.
« Last Edit: October 16, 2021, 10:13:38 am by Nooobie »
