Since few days i'm working on a screen project with my MSP430F5529 and one ili9341 screen.
I have take an exemple (from arduino, can't find on MSP) and adapt it to know how use the screen.
After few try, i can fill the screen with colors but can't draw a simple line or rectangle at a special position.
When i run the program step by step, all instruction command work and on the screen i have all the program what have to do.
I have try to change all wire but no change.
The MSP430F5529 run at 25 MHz (max) with 3.3V like the screen.
//This application does not rely on any libraries and it is for ILI9341
//This program is a demo of clearing screen to display black,white,red,green,blue.
//when using the BREAKOUT BOARD only and using these hardware spi lines to the LCD,
//the SDA pin and SCK pin is defined by the system and can't be modified.
//if you don't need to control the LED pin,you can set it to 3.3V and set the pin definition to -1.
//other pins can be defined by youself,for example
//pin usage as follow:
// CS DC/RS RESET SDI/MOSI SCK LED VCC GND
// GND
//Remember to set the pins to suit your display module!
#include <msp430.h>
#define FPROC 25000000
P3.0 : MOSI
P3.1 : MISO
P3.2 : CLK
#define RSUP P6OUT|=BIT0 // DC/RS
#define RSDOWN P6OUT&=~BIT0
#define LEDUP P6OUT|=BIT1
#define LEDDOWN P6OUT&=~BIT1
#define CSUP P6OUT|=BIT2
#define CSDOWN P6OUT&=~BIT2
#define RESETUP P6OUT|=BIT3
#define RESETDOWN P6OUT&=~BIT3
unsigned long oldrand = 5468;
void SetVcoreUp (unsigned int level)
// Open PMM registers for write
PMMCTL0_H = PMMPW_H;
// Set SVS/SVM high side new level
SVSMHCTL = SVSHE + SVSHRVL0 * level + SVMHE + SVSMHRRL0 * level;
// Set SVM low side to new level
SVSMLCTL = SVSLE + SVMLE + SVSMLRRL0 * level;
// Wait till SVM is settled
while ((PMMIFG & SVSMLDLYIFG) == 0);
// Clear already set flags
PMMIFG &= ~(SVMLVLRIFG + SVMLIFG);
// Set VCore to new level
PMMCTL0_L = PMMCOREV0 * level;
// Wait till new level reached
if ((PMMIFG & SVMLIFG))
while ((PMMIFG & SVMLVLRIFG) == 0);
// Set SVS/SVM low side to new level
SVSMLCTL = SVSLE + SVSLRVL0 * level + SVMLE + SVSMLRRL0 * level;
// Lock PMM registers for write access
PMMCTL0_H = 0x00;
// fonction aleatoire
unsigned int random(unsigned int n) {
unsigned long nn = oldrand;
oldrand = (unsigned int)((859*nn)%6823);
return oldrand % n;
void delay(unsigned int i){
while(i--)
__delay_cycles(FPROC/1000); // 1000 for 1MHz
// envoyer sur le SPI la donnée
void Lcd_Writ_Bus(unsigned char d)
while(UCB0STAT&BIT0) {} // si la communication n'est pas finie on attend
UCB0TXBUF = d;
// écrire la commande
void Lcd_Write_Com(unsigned char VH)
RSDOWN; //LCD_RS=0;
Lcd_Writ_Bus(VH);
// écrire la donnée
void Lcd_Write_Data(unsigned char VH)
RSUP; //LCD_RS=1;
Lcd_Writ_Bus(VH);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
Lcd_Write_Com(0x2a);
Lcd_Write_Data(x1>>8);
Lcd_Write_Data(x1);
Lcd_Write_Data(x2>>8);
Lcd_Write_Data(x2);
Lcd_Write_Com(0x2b);
Lcd_Write_Data(y1>>8);
Lcd_Write_Data(y1);
Lcd_Write_Data(y2>>8);
Lcd_Write_Data(y2);
Lcd_Write_Com(0x2c);
void draw_pixel (unsigned char cr,unsigned char cv,unsigned char cb) {
Lcd_Write_Data(cr);
Lcd_Write_Data(cv);
Lcd_Write_Data(cb);
void SPI_Init(void)
UCB0CTL0 = BIT7 | BIT5 | BIT3; // Master + MSBfirst + front montant + CLK inactif 0
UCB0CTL1 = BIT7 | BIT6; // SMCLK
P3SEL |= 0x07; // on utilise le SPI (CLK, MOSI et MISO)
void Lcd_Init(void)
RESETUP;
delay(5);
RESETDOWN;
delay(15);
RESETUP;
delay(15);
CSDOWN; //CS
Lcd_Write_Com(0xCB);
Lcd_Write_Data(0x39);
Lcd_Write_Data(0x2C);
Lcd_Write_Data(0x00);
Lcd_Write_Data(0x34);
Lcd_Write_Data(0x02);
Lcd_Write_Com(0xCF);
Lcd_Write_Data(0XC1);
Lcd_Write_Data(0X30);
Lcd_Write_Com(0xE8);
Lcd_Write_Data(0x85);
Lcd_Write_Data(0x78);
Lcd_Write_Com(0xEA);
Lcd_Write_Com(0xED);
Lcd_Write_Data(0x64);
Lcd_Write_Data(0x03);
Lcd_Write_Data(0X12);
Lcd_Write_Data(0X81);
Lcd_Write_Com(0xF7);
Lcd_Write_Data(0x20);
Lcd_Write_Com(0xC0); //Power control
Lcd_Write_Data(0x23); // 23 VRH[5:0]
Lcd_Write_Com(0xC1); //Power control
Lcd_Write_Data(0x10); //SAP[2:0];BT[3:0]
Lcd_Write_Com(0xC5); //VCM control
Lcd_Write_Data(0x3e); //Contrast
Lcd_Write_Data(0x28);
Lcd_Write_Com(0xC7); //VCM control2
Lcd_Write_Data(0x86); //--
Lcd_Write_Com(0x36); // Memory Access Control
Lcd_Write_Data(0x48); // 48 (28 -> mode paysage, 48 -> mode portrait)
Lcd_Write_Com(0x3A); // Pixel format set
Lcd_Write_Data(0x66); // 55
Lcd_Write_Com(0xB1);
Lcd_Write_Data(0x18); // 18
Lcd_Write_Com(0xB6); // Display Function Control
Lcd_Write_Data(0x08);
Lcd_Write_Data(0x82); // 82
Lcd_Write_Data(0x27);
Lcd_Write_Com(0x11); //Exit Sleep
delay(120);
Lcd_Write_Com(0x29); //Display on
CSUP;
void H_line(unsigned int x, unsigned int y, unsigned int l,unsigned char cr,unsigned char cv,unsigned char cb)
unsigned int i;
CSDOWN;
Lcd_Write_Com(0x02c); //write_memory_start
Address_set(x,y,l+x,y);
for(i=1;i<=l;i++)
draw_pixel(cr, cv, cb);
CSUP;
void V_line(unsigned int x, unsigned int y, unsigned int l,unsigned char cr,unsigned char cv,unsigned char cb)
unsigned int i;
CSDOWN;
Address_set(x,y,x,l+y);
for(i=1;i<=l;i++)
CSUP;
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned char cr,unsigned char cv,unsigned char cb)
H_line(x , y , w, cr, cv, cb);
H_line(x , y+h, w, cr, cv, cb);
V_line(x , y , h, cr, cv, cb);
V_line(x+w, y , h, cr, cv, cb);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned char cr,unsigned char cv,unsigned char cb)
unsigned int i;
for(i=0;i<h;i++)
H_line(x , y+i, w, cr, cv, cb);
void LCD_Clear(unsigned char cr,unsigned char cv,unsigned char cb)
unsigned int ii,mm;
CSDOWN;
Address_set(0,0,240,320);
for(ii=0;ii<240;ii++)
for(mm=0;mm<320;mm++)
CSUP;
void LCD_Arc()
unsigned int ii,mm;
unsigned char cb = 0, cv = 0, cr = 0;
CSDOWN;
for(ii=0;ii<320;ii++) {
if (ii<80) cr=3*(ii%80);
else if (ii<160) cr=3*(80-(ii-80)%80);
else if (ii<240) cb=3*((ii-160)%80);
else cb=3*(80-(ii-240)%80);
for(mm=0;mm<240;mm++)
cv = mm%240;
CSUP;
void LCD_Carre()
unsigned int ii;
CSDOWN;
Address_set(10,10,20,20);
for(ii=0;ii<100;ii++) {
draw_pixel(0xff, 0xff, 0xff);
CSUP;
* main.c
void main(void)
WDTCTL = WDTPW | WDTHOLD; // stop watchdog timer
SetVcoreUp(1);
SetVcoreUp(2);
SetVcoreUp(3);
UCSCTL3 |= SELREF_2; // Set DCO FLL reference = REFO (32 768)
__bis_SR_register(SCG0); // Disable the FLL control loop
UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; // Select DCO range 25MHz operation
UCSCTL2 = FLLD_0 + (FPROC/32768 - 1); // Set DCO Multiplier for 25MHz (487 pour 16MHz) (761 pour 25MHz)
// (N + 1) * FLLRef = Fdco
// (761 + 1) * 32768 = 25MHz
// Set FLL Div = fDCOCLK
__bic_SR_register(SCG0); // Enable the FLL control loopthen select clock source by write SPI control register (UCSSELx)
UCSCTL4 |= SELA_3; // présence de MCLK/1024 sur P1.0
UCSCTL5 |= DIVPA_5 | DIVA_5;
P1DIR |= BIT0;
P1SEL |= BIT0;
SPI_Init();
P6DIR |= 0x0F; // bit0 à 3 en sortie
RSUP;
LEDUP;
CSUP;
RESETUP;
Lcd_Init();
while (1) {
LCD_Clear(0xff, 0xff, 0xff);
delay(1000);
LCD_Clear(0xff, 0x00, 0x00);
delay(1000);
LCD_Clear(0x00, 0xff, 0x00);
delay(1000);
LCD_Clear(0x00, 0x00, 0xff);
delay(1000);
LCD_Arc();
delay(3000);
LCD_Carre();
delay(5000);
LCD_Clear(0x00, 0x00, 0x00);
Rect(10,10,100,50,random(256),random(256),random(256));
/*for(i=0;i<100;i++)
Rect(random(239),random(319),random(239),random(319),random(256),random(256),random(256)); // rectangle at x, y, width, hight, color
delay(5000);
__bis_SR_register(LPM4_bits);
Thank you for help.
