Author Topic: Measuring power consumption of dual supply circuit  (Read 2189 times)
Offline jram112Topic starter
« on: December 07, 2012, 08:03:32 am »
I want to measure the power consumption of my opamp circuit. I understand for a single supply circuit that I can take the supply voltage, measure the current, and then compute the power. However, for a dual supply circuit there are two supply voltages. Should I measure the power from both the positive and negative supply then add them together? Should I measure them simultaneously, etc?
Also, I have the EEVblog uCurrent. Should I be concerned with the virtual ground being connected to the current input terminals?
Thanks
Offline Zero999
  • 0999
Re: Measuring power consumption of dual supply circuit
« Reply #1 on: December 07, 2012, 01:50:58 pm »
To compute the power, you need to measure two currents and two voltages. It doesn't matter whether you measure the +V to -V and +V to 0V or -V to 0V, just as long as you have two voltage and two current measurements. Look at the Ohm's law formula and you'll see what I mean.
