Author Topic: [Solved] Unity Gain Differential Amplifier not working as expected  (Read 8236 times)
Offline king.osloTopic starter
  • Country: no
Hello there,
I made an Unity Gain Differential Amplifier circuit. This tutorial told me that Vout = V2-V1: http://www.electronics-tutorials.ws/opamp/opamp_5.html
My exact schematic is attached. R1-R4 are 22R3
The problem is that Vout != V2-V1.
I built it up using a Microchip MCP6041 on a bread board. This is what I found:
Case 1:
V2: =1.475V
V1: =2.835V
Expected Vout = -1.36V
Vout = 1.936V
Expected Vout != Vout
Case 2:
V2: = 0.982V
V1: = 2.829V
Expected Vout = -1.847
Vout = 1.930
This is the datasheet for the opamp: http://ww1.microchip.com/downloads/en/DeviceDoc/21669c.pdf
What have I missed?
Thanks for your time.
Kind regards,
Marius
« Last Edit: January 13, 2012, 08:42:05 am by king.oslo »
Offline IanB
Re: Unity Gain Differential Amplifier not working as expected
« Reply #1 on: January 13, 2012, 12:27:00 am »
Are you supplying the op amp with a dual rail supply? You have not said how you are powering it.
You cannot expect to get a negative voltage out of an op amp unless you have a negative supply voltage fed into it.
  • Country: no
« Reply #2 on: January 13, 2012, 12:35:30 am »
Opamp is powered by 5VDC to gnd. I think you just pointed out the problem.
Offline slateraptor
« Reply #3 on: January 13, 2012, 12:36:19 am »
Here's your problem, viz. your lower rail is tied to ground, thus cannot produce negative voltage.
  • Country: no
« Reply #4 on: January 13, 2012, 12:39:23 am »
That's great.
It says my opamp can only do  1.4V to 6.0.
Does that mean that I power it like this: VDD = 6V, VSS = 0V. Then pull inverting input to 3VDC, and then measure Vout between Vout and 3VDC?
1. That should work, right?
2. Is this the traditional way to do it?
Thanks.M
Offline slateraptor
« Reply #5 on: January 13, 2012, 01:11:21 am »
Instead of tying R4 to ground, tie it to Vcc/2. Then measure your output with respect to Vcc/2. This is standard single-supply practice.
EDIT: If you analyze the circuit assuming the op amp is ideal, you can easily see why this will work. I encourage you to give it a shot.
« Last Edit: January 13, 2012, 01:19:26 am by slateraptor »
  • Country: no
« Reply #6 on: January 13, 2012, 02:24:05 am »
Thanks.
Since I wasn't doing this, I was measuring Vout with respect to gnd, and tying R4 to gnd as well. What values was I actually measuring?
Thank you for you time. Both of you.
Kind regards,
Marius
Offline slateraptor
« Reply #7 on: January 13, 2012, 02:53:04 am »
The op amp's output wasn't within its normal operating region; you were effectively measuring junk.
  • Country: no
« Reply #8 on: January 13, 2012, 08:40:02 am »
Ok, thanks! :)  ;D M
