Author Topic: RF attenuator formula. I am confused ...  (Read 2662 times)
Offline JacquesBBBTopic starter
« on: July 09, 2015, 08:16:46 am »
Dear All,
I do not understand the RF attenuator formula that I find in many places  on the Web.
As for example in http://www.qsl.net/4f5aww/module5p.htm
If I compute the resulting voltage divider  ratio, I find
R1/(R1+R2) = 2k/(k^2+1) ~ 2/k
and not 1/k  as one would expect for a k factor attenuation.
I am sure I am missing something, but what ?
Thanks
Offline w2aew
    • My YouTube Channel
Re: RF attenuator formula. I am confused ...
« Reply #1 on: July 09, 2015, 12:12:46 pm »
What you're missing is the fact that both ends of this attenuator are terminated in 50 ohms when used in RF applications.
FAE for Tektronix
« Reply #2 on: July 09, 2015, 08:48:46 pm »
Thanks, w2aew, for the comment.  This was missing in the web sites I looked to.
It is also missing on your video, which is nevertheless very interesting.
So I have added a Z  impedance in parallel to the R1 resistors.
Now the  ratio of the voltages is  (using the formula given above)
Vo/Vi = R1*Z/(R1*R2 +(R1+R2)*Z) = 1/k
So exactly what is needed.
This means that the impedance of  the attenuator needs to be adjusted to the impedance  of the
source and of the receiver.
Thanks again.
Offline w2aew
« Reply #3 on: July 10, 2015, 12:29:02 am »
Thanks again.
Yes, this is one of those *given* or *assumed* things in RF applications.
FAE for Tektronix
Offline LukeW
« Reply #4 on: July 10, 2015, 04:50:15 am »
Yep, it is assumed that the attenuator you're designing is going into a system with some impedance given, say 50 ohms. And if you build that attenuator and then move it to a 75 ohm system it will not work as intended.
