Hi KDORC,
Thanks for the info and encouragement.
Based on your post I did some searching. Looks like SoftRock is indeed a very good possible starting point.
I'm now looking for more info to compare FlexRadio and SoftRock. So far I've found this:
http://www.sdrtransceiver.com/
You have me thinking harder more about the ham radio license. Are you a ham with a license? (Which license?) What have you found most interesting with the 815TG?
If I'm going to get a license, maybe it makes sense to go straight for a SoftRock transceiver?
I need to get up to speed on the various meters/bands, etc. Any recommendations welcome...
Thanks again, EF
Yep, I am a ham. My call is the same as my name here - KD0RC. I have an Extra Class license, so I have all the privileges available. I suggest getting a book on the subject so that you can see what is available to the various license classes, and also to see what it takes to attain those licenses. Building a receiver or transciever while you are working on getting your license is a good way to stay motivated to keep going. A good source of info is
http://www.arrl.org/Buying a used receiver to use while you are learning is not a bad way to go either. You can get a sense of operating procedure and start to figure out what to do for an antenna (not all receiving antennas make good transmitting antennas, but many do).
Comparing the SoftRock with a FlexRadio is like comparing a go-kart with a Lamborghini... I bought my SoftRock receiver to learn from; it was fun to build and I play around with it all the time, but I don't use it in my regular ham communications.
The Technician license essentially gives you 10 Meters (28 - 28.5 MHz) and all higher bands.
General, Advanced and Extra give you all bands starting at 160 Meters (1.8 - 2 MHz).
It is not bad to start with the Technician and work your way up. If you are more interested in HF (10 M and lower), then it might be good to go straight for the General.
The best part of the DSA 815 is how much I am learning from it. I have wanted a spectrum analyzer for years, and this is the first one that I can afford and has a tracking generator that I can use to characterize filter response and also use to check my antennas.
Best of luck with this, ham radio has been a real fun thing for me for many years.
