Author Topic: Phase Measurement in LT Spice  (Read 4926 times)
Offline eev_carlTopic starter
« on: December 07, 2018, 02:07:38 pm »
Am I applying this .meas directive correctly?  I'm trying to get the phase angle between the two sine waves.  On the scope, I measured this at about 80 degrees but am getting 63 degrees from .meas.
Thanks,
Carl
Online Ian.M
Re: Phase Measurement in LT Spice
« Reply #1 on: December 07, 2018, 02:51:23 pm »
Attach your sim as a .asc file so others can check it easily.
The following users thanked this post: eev_carl
« Reply #2 on: December 07, 2018, 03:10:56 pm »
Here's my .asc
« Reply #3 on: December 07, 2018, 03:16:17 pm »
Also, with regards to the scope picture...the yellow sine wave is a direct connection from the function generator. I'm using a BNC splitter.  The other half of the splitter goes to the circuit.  The blue sine wave is at the junction of the R and the E.
Online Ian.M
« Reply #4 on: December 07, 2018, 04:01:12 pm »
Why did you strip the .measure commands?
.meas TRAN TIME_1 TRIG V(Vin)=0 RISE=2 TARG V(Vin)=0 RISE=3
.meas TRAN TIME_2 TRIG V(Vin)=0 RISE=2 TARG V(Vout)=0 RISE=2
.meas phase param 360*(TIME_2/TIME_1)
With the .tran 0 1m .5m command from the sim you attached, I am also getting about 80 deg, confirmed by cursor measurements.   With your original .tran 50m I'm getting the same bogus 63 deg you got.
I suspect the cause is too many cycles and not enough data points due to your initially ill-chosen simulation duration.
« Reply #5 on: December 07, 2018, 04:48:49 pm »
Sorry about the .meas.  I posted the .asc before saving.  Thanks for the note on the duration.
Offline mikerj
« Reply #6 on: December 07, 2018, 05:08:44 pm »
The cause is the DC shift in the first few cycles. Ignoring this data by adding the 0.5ms recording start time fixes the problem rather than the simulation duration.
The following users thanked this post: Ian.M, eev_carl
