Author Topic: 1.2V LVCMOS to 3.3V LVTTL level shifter  (Read 931 times)
Offline twitzelbosTopic starter
« on: February 07, 2023, 08:26:54 pm »
Hello all,
I'm in need of an 8 Bit unidirectional level shifter that takes 1.2V LVCMOS input signals and turns them into 3.3V TTL output signals. There are a gazillion ICs out there, but I don't seem to be able to confidently select one with the search function in Digikey or on manufacturer websites. The data rate would be roughly 50 Mbps.
Can someone please recommend an IC that will work for this application?
Thank you,
Thomas
« Last Edit: February 07, 2023, 11:17:45 pm by twitzelbos »
Offline Benta
Re: 1.2V LVCMOS to 3.3V LVTTL level shifter
« Reply #1 on: February 07, 2023, 09:11:20 pm »
LCMOS to TTL at 50 Mbps? Are you sure? Or do you mean LVCMOS?
Ah! I see you fixed the OP. Gotcha.
« Last Edit: February 07, 2023, 09:18:43 pm by Benta »
« Reply #2 on: February 07, 2023, 09:14:26 pm »
Yep, we have this working at 3.3V routinely, but now we have a FPGA board that only outputs 1.2V on this port. We are operating SPI near its limits on this (actually mostly 39.5 Mbps, but occasionally higher).
Thomas
Offline langwadt
« Reply #3 on: February 07, 2023, 09:35:22 pm »
The following users thanked this post: edavid, twitzelbos
« Reply #4 on: February 07, 2023, 11:24:51 pm »
Thank you. Do I read the datasheet correctly, that I would then supply Vcc_A with 1.2V as this is the logical level I'd have on the input, and Vcc_B with 3.3V?
Thanks again,
Thomas
Offline langwadt
« Reply #5 on: February 07, 2023, 11:41:42 pm »
Thanks again,
Thomas
yes
The following users thanked this post: twitzelbos
« Reply #6 on: February 08, 2023, 02:01:36 am »
Thank you!!
