Hello all,
I'm in need of an 8 Bit unidirectional level shifter that takes 1.2V LVCMOS input signals and turns them into 3.3V TTL output signals. There are a gazillion ICs out there, but I don't seem to be able to confidently select one with the search function in Digikey or on manufacturer websites. The data rate would be roughly 50 Mbps.
Can someone please recommend an IC that will work for this application?
Thank you,
Thomas
