Hi guys,
im in no way a pro, but a hobbyist, and i have been trying to create a 555 timer wihtout the use of a microchip (ie just with transistors) i have built the following circuit 4 times
and have added some stuff to the front in order to make an a-stable 555 timer, however on every occassion all im getting is a continuous output of on.. 4 different times, (first 2 on breadboard, the second two on circuit board)
is this actually a correct schematic for the 555 timer.?
im using
2n2222 Npn transistors
2n3904 Pnp transistors
and
1n4002 diodes
cheers
